I have 47 collections ; a very big user of waypoints .After creating , say ten collections , anything thereafter stops responding .
Full synchronisation with Garmin Explore successful , just not with XT2
I have tried complete reset of XT3 and re installation to Tread .
Going to phone Garmin tomorrow
Tread Collections not synchronising to XT2
Re: Tread Collections not synchronising to XT2
ZumoGSer wrote: ↑Mon Jan 27, 2025 8:39 pm I have 47 collections ; a very big user of waypoints .After creating , say ten collections , anything thereafter stops responding .
I have tried complete reset of XT2 and re installation to Tread .
The same thing happens to me. When I synchronize several of my "old" collections, and a lot of material comes together on the XT2, the synchronization stops working properly, and the Tread App starts disconnecting.
So glad that I'm not the only one .
I have deleted all data and reset XT2
Resynchrinised with Tread and all collections now not listed : just 3,000 Unorganised items
So disappointing, considering that Tread and Garmin Explore website are perfectly synchronised
ZumoGSer wrote: ↑Tue Jan 28, 2025 1:28 pm So glad that I'm not the only one .
Resynchonised with Tread and all collections now not listed : just 3,000 Unorganised items
That's right, the same thing has happened to me several times. The only solution I have found is to not activate Explore sync in the XT2, this way many collections can be imported without problems . It doesn't happen with 4-6 collections, but when it goes beyond 12, and with a lot of synchronized material as you say, the problems begin.
Exactly
GARMIN need to know this
Once you have x number of collections , it stops synchronising
FIXED temporarily I guess ( no help from Garmin ), lots of trial , error and failure .
1) Make sure that Tread shows itself synchronising , if not redo the setup ( first the moment ignore the fact that the faulty Collections do not synchronise )
2) Tread , open the MAP and create a new waypoint and call it TEST
3) Tread ; save the TEST waypoint in EVERY COLLECTION , by selecting them all
You will then discover that all collections will synchronise and abd vanished will reappear
Magic !!!
4) Delete TEST , from the map ( which opens them all )
Easy !
My thinking is that something has confused the gpx files
A gpx file is completely overwritten as a new data file, when a new waypoint is added
A Collection is simply a gpx file , containing all waypoints and or routes .
Adding a new file to the Collecton creates a new gps , so adding your all effectively generates a complete new Collection
Magic !!!
Easy !
ZumoGSer wrote: ↑Tue Jan 28, 2025 6:50 pm FIXED
Temporarily I would guess ( no help from Garmin ), lots of trial , error and failure .
1) Make sure that Tread shows itself synchronising , if not redo the setup ( firstly ignore the fact that the faulty Collections do not synchronise )
Magic !!!
4) Delete TEST (because no longer needed) , from the map ( because map selects all the collections which show Test )
Easy !
Adding a new file to the Collecton creates a new gpx , so adding your all effectively generates a complete new Collection
(Above edited for better grammar)
Fixes that Garmin users have to make because their software is regrettable. Do Garmin engineers do any tests? because if they left me in their office for 2 hours I would find several bugs in their software .ZumoGSer wrote: ↑Tue Jan 28, 2025 6:50 pm FIXED temporarily I guess ( no help from Garmin ), lots of trial , error and failure .
Magic !!!
Easy !
