Upgrade from XT to XT2
Upgrade worth it from XT to XT2?
Yes, it is much better
1
14%
On balance if you have the XT keep it but the XT2 is nice
3
43%
No, don't spend the 800Euros, keep the XT
0
No votes
Wait until the next upgrade XT3..
3
43%
Total votes: 7
Chopperbob
Has liked: 14 times
Post by Chopperbob »
So is it worth it?
I like the thumb control that can be connected to the XT2,
But on balance is the XT2/Tread a significant better system than the XT/Basecamp combi?
Has liked: 55 times
Been liked: 44 times
Re: Upgrade from XT to XT2
I had an XT and moved to the XT2 about 8 months ago so I’ve had a reasonable amount of experience with each. If I had neither and was looking for a first purchase, I would go with the XT2, but If I already had an XT, I would not spend the money to "upgrade".
The XT2 is definitely better hardware with a bigger, brighter screen and has a few nice features including the keyboard on one screen, the ability to sort routes, etc. However, the XT2 software still suffers from the same important problems as the XT – e.g. RUT. You can find workarounds for those issues that work for both the XT and XT2 but why spend money to keep the same problems? In addition, the Tread app with the XT2 introduces a whole new set of significant issues. Tread and the XT2 might become a great system someday, but so far Garmin appears to be very slow, and even reluctant, to fix the issues, at least as I see it.
At this point, I use my XT2 in a similar manner to my previous XT. After several attempts with the Tread app, I now avoid it entirely, primarily because it makes significant, undesirable route changes, especially when shaping points are included. It also introduces Bluetooth issues. There are posts about those, and other issues, on this forum.
For route planning, I still use Basecamp, which runs on a big screen computer rather than a small screen phone or tablet. Yes Basecamp does work just fine with the XT2, as do several third party tools. I import gpx files to the XT2 via sd card. I find it simple and reliable.
For perspective, the primary reason I have a SatNav (aka a GPS) on my motorcycle is for planned route navigation, with spoken directions. The second reason is to always have a map handy when I’m not following a planned route. Third would be the ability to search for nearby facilities and attractions. The various other features available are nice extras, but they are not why I bought the device in the first place. When an app like Tread adds nice to have features but breaks the much more important base functionality, it gets purged from my devices.
Has liked: 426 times
Been liked: 933 times
There is no option for what I want to select in the quiz.
The XT1 has its issues. Serious issues. But I now know how to make it behave in the way that I want it to behave - ie more like the Zumo 590. Predictable. Reliable. Pity about the 590's dim screen and the battery that never properly charges.
So the XT1 may change the name of route points on transfer. It will definitely mess up your route if the route is impoted from BC or obtained from a GPX file - if it is allowed to recalculate the route - eg by needing to press Skip. You can get round most of these issues using various techniques.
The XT2 is not physically that much bigger than the XT1 - but the visible display is XT2: 133mm x 75mm XT1: 121mm x 68mm
This makes makes the are 21% larger, and the display is much brighter - a whiter light.
The XT2 comes with souped-up issues - most of which I have eliminated by refusing to link the XT2 with the Tread's route storage. I can still use the Tread App for Road works, traffic, weather info. But not allowing it to synch to the Tread/Explore database means that routes and routepoints are not changed.
I do like the fact that collections are now properly implemented on the XT2, so all data for a single day's ride (routes, tracks, waypoints) can be saved in a collection for a single day - and that collection can be displayed on the map, and all others turned off. The RUT issue which plagued the XT1 - is fixable. On the XT2, this can be achieved very easily using the XT2 screen.
I still have a 590 and a 595 - but the cradles are no longer mounted on the motorbike.
The XT2 cradle is in prime position on the dash - a simple glance away. The XT1 cradle is still there between the bars just above the tank. Difficult to just glance at - but on unknown routes I will take both. But I am happy enough with the XT2 to have it as my main unit. But it is not as Garmin would intend it.
Garmin has now developed a remote handle bar controller for the XT2. I have one - but goodness what were Garmin doing with the info that they provided about the cables that were required ? I cannot comment on how well it works as I have only just obtained a refund for the cables that they originally recommended, and the replacement will be available in 4-7 days. (But it said that a couple of weeks ago).
Has liked: 130 times
Been liked: 102 times
I like the XT2 for it's ability to route plan off the unit, and not having to use a computor / laptop to do it.
But I still use Basecamp to route plan for the XT2, but then do the dance of sending the routes by e-mail to myself for Tread / XT2 synchronisation.
But I'll be keeping my XT as Garmin Express doesn't seem to let me download maps to the laptop, probably because Garmin say that the XT2 isn't officially supported so why would I need maps on it :(
Oop North John wrote: Thu Jan 30, 2025 8:21 pm But I'll be keeping my XT as Garmin Express doesn't seem to let me download maps to the laptop, probably because Garmin say that the XT2 isn't officially supported so why would I need maps on it :(
So far I have not had issues updating the maps on my PC with the XT2 connected. Last time, it wouldn't let me install to the PC until it had already installed them on the XT2.
But you make a good point. You can always install maps to the PC if you have an older Garmin (eg the XT1, 595, 590, ....)
At some point in the past, for doing something else, I read that you can insert an SD card which has been formatted/named/loaded with files/... I do not recall - actually I didn't take much notice because it wasn't something that I had the need to use at the time. But apparently in doing so, the content of the card made it look like a particular Zumo was connected - which allowed certain things to be done that otherwise could not be done.
I'm wondering if the magic SD card trick would allow maps to be installed on the PC.
Am I talking rubbish - or is this a possibility ?
jfheath wrote: Thu Jan 30, 2025 10:38 pm At some point in the past, for doing something else, I read that you can insert an SD card which has been formatted/named/loaded with files/... I do not recall - actually I didn't take much notice because it wasn't something that I had the need to use at the time. But apparently in doing so, the content of the card made it look like a particular Zumo was connected - which allowed certain things to be done that otherwise could not be done.
I think that the correct term is creating a virtual drive, which Basecamp then "sees" as a real Garmin GPS.
Lots of articles on a Garmin forum which links to the page below page. I did something like this in the past for out of the GPS's normal mapping area, so it could be more quickly used than accessing the maps through the GPS. Usual caveats, you decide if you want to use it!
https://www.javawa.nl/virtualdevice.html
Chopperbob
Has liked: 14 times
I saw the tread 2 this weekend,.... hmmmm
Would that work on a bike?
There are several things I like, you can define different profiles for different vehicles...
I have read that the Tread unit is more suited to off road navigation. I don't know if that means road nav features are reduced.
I also saw mention that maps were different. How, I do not know.
People on t'internet say a lot of things without really knowing for certain - and I never believe what I read anyway. I take note and if I am vaguely interested I check it out for myself. People very rarely admit that they don't know. They just talk a load of drivel instead.
(By 'people' - I mean in the big wide world - not on this forum. We're a bit special !)
So I'll answer the question properly: I don't know.
JS_racer
Has liked: 9 times
Post by JS_racer »
say, xt2, does tread link with explorer, or is explorer separate on the xt2 ??
what are the issues with tread sending routes, trips, tracks and such to the xt2??
my xt died, and is being swapped on their refurb program, but debating getting the xt2, since I've had the xt since like 2020
thanks for your time
Has liked: 55 times
@JS_racer
I'll try to provide a quick answer here. You can find a lot more detail throughout this forum.
First, some clarification. Unfortunately Garmin uses "tread" and "explore" to refer to multiple things. The XT2 can be paired with the Tread App on a phone or tablet. That Tread App can sync routes with the Explore database. You can view them on the Explore web page if you have an account. That Explore does not support shaping points, which leads to issues when syncing routes. The routes can be changed significantly when sync'd.
As I said in a previous post above (my opinion), the XT2 is superior hardware to the XT with some nice features, but I use my XT2 like the XT. I avoid the Tread App and the Explore database entirely. Hopefully, Garmin will fix those issues eventually. I currently plan routes with Basecamp and import them via sd card. Yes Basecamp does work with the XT2, despite the warnings. The XT2 just has some features which Basecamp does not support.
Others on this forum do use the Tread App and have various work-arounds for the issues involved.
