Zumo 590 update cable for Mac
Trapper
Ireland
Post by Trapper »
Hi all,
I have recently upgraded my Mac to Sequoia 15.3.1 and the Mac Mini no longer has options to use the supplied Garmin 590 USB A with (I think) USB mini cable. Unfortunately, connection is not possible using a hub that has all the older slots. What I now need for any future updates is a USB mini to USB C cable. Have any of you folk had the same issue and how did you source the appropriate cable?
Thanks in advance.
Trapper
BMW K1 1990. BMW K1100RS 1995. BMW K1200RS 2000.
Re: Zumo 590 update cable for Mac
The USB socket on the 590 takes a micro USB plug. A query in any search engine for "micro USB to USB C" or "USB A to USB C" should find many cord or adapter options.
Trapper
Ireland
Post by Trapper »
Enormous thanks Ikraus,
Yeah, I did that search, bought the cable and no joy. Perhaps it was not the cable for data transfer? The search continues.
Best wishes
Trapper
My new Lenovo laptop only has one USB A port. The rest are USB C ports. My wireless mouse dongle occupied the USB A port so I purchased a USB C to multiport USB A hub. I can then use the Garmin cable to connect my XT, as well as the numerous other external devices I own that have USB A cables.
twowheelstom
Has liked: 146 times
Been liked: 54 times
Post by twowheelstom »
Trapper wrote: Sat Feb 15, 2025 6:42 pm What I now need for any future updates is a USB mini to USB C cable.
I see this cable here on Amazon.ca
Cable Matters USB C to Mini USB Cable (Mini USB to USB-C Cable) 6.6 Feet in Black
Zumo 396
1994 Yamaha 250
Trapper
Ireland
Post by Trapper »
Thanks twowheelstom,
Much appreciated.
Alyn
OldRS
Has liked: 44 times
Been liked: 6 times
Post by OldRS »
Trapper wrote: Mon Feb 17, 2025 6:52 pm Thanks twowheelstom,
Much appreciated.
Alyn
Were you able to obtain a USB C to USB Micro - if that's what it is - cable which enables data transfer to and from your 590 from a MAc with only USB C sockets?
I'm contemplating buying an Apple Neo but am concerned about not being able to use the Garmin-supplied USB cable.
Ta
Richard
