Tried Tread this morning, still the same, so with some trepidation, uninstalled the app, and re-installed it.
I now have the CN style mapping in addition to the basemap showing, and it didn't force me into sharing the info which jfheath seems to get. IIRC the shaping points have always been unidentified, and so that's another reason I only only via / way points. Stops a little bit of the swearing at Tread!
Some waypoints seem to show irrespective of zoom level, some appear / disappear at varying zoom levels.
Routing is back working.
Tread still at 2.09.63.
- Has liked: 125 times
- Been liked: 92 times
I have been able to install Tread App without synchronization. Try following these steps:jfheath wrote: ↑Wed Feb 19, 2025 7:29 am Update Summary of Garmin 'Improvements'
I bought one product -an XT2 -full of promise. It seems that it is being downgraded to a Zumo 660 equivalent - No shaping points, no smartphone data links, all data transfer by cable, ..... Unless I want to use the Tread Magical Mystery Tour features.
- Ability to install Tread without it synching / storing your data is no longer possible with Tread v 2.09.63
- Tread does not have to be connected, but if not, you lose weather, traffic, road closure and fuel data.
- In the Tread Route Planner, it is still not possible to insert shaping points - except in strict sequence of travel
- It is no longer possible to reorder shaping points in the Tread app. Even when it was possible, it was difficult because all are called 'Shaping Point'
- Changing a Via Point to a shaping point in the Tread App still often results in the route and the via point being moved to a faster road. I don't know what the purpose of a shaping point is.
- Allowing any gpx route to synchronise via Tread App often results in relocation of route and shaping points. This includes gpx routes exported by the Tread app - so it is not a Basecamp issue.
- Current Tread Driving Map is so cluttered with detail and shading, it is now extremely difficult to see town names road names and roads. They do not scale up when you zoom in, but more 'clutter' is added.
- Tread app still does not allow creation of Tracks eg from a route.
- Basecamp maps can no longer be put onto the computer. Unless you have an older Zumo to plug in.
That's not quite fair. If you create a route with the Tread App, it transfers and works perfectly.
So I would really expect the Tread App to be usable. The sort of tool that exceeds the capabilities of BC. But it doesn't. It falls a long way short. The tools most frequently used by me in BC are 'insert' and 'change via to/from shaping'.
It's not just a small smartphone screen issue. I use an ipad when attempting to use it.
I see lots of positive posts about the XT2. How are people using them ? I'm desperately trying to make it work and It's very difficult.
But .... thinking positively
I can choose not to install Tread and sacrifice weather, traffic, fuel data, route transfer via email.
I can still prepare routes and send via gpx file and Usb cable
I can prevent Rut behaviour by making a copy of the route from the XT2 screen
And it does have a nice, bright, large screen
Oh and a handlebar controller which I will now have to reprogram as I cant use weather, traffic, fuel etc.
And I get to have another phone call with tech support and send a follow up email to product.support
And I like puzzles so its all good fun really. It does bother me that this state of the art technology may be the future that we see in software development for Artificial Intelligence, for driverless cars, and for online banking.
Anyway, today I'm not doing any of that. Wheels are off the bike, today they are having new rubber fitted.
I was hoping to get new T33s but they are still not available.
1- Master Reset Zumo XT2
2- Uninstall Tread App from your mobile (with XT2 turned off, so that it does not detect the "nearby devices of the Android option")
3- With the Xt2 turned off, unpair the XT2 from your mobile's bluetooth list.
4- Perform the phone and Xt2 installation as normal, and do not activate cloud storage in the last steps of the APP installation.
If the XT2 at any time during a reinstall of the Tread app detects a previously installed device, it attempts to revert to the previous Bluetooth configuration with that device, including synchronization.
This way you will have the weather, traffic, fuel prices! etc.
When I re-installed Tread I only had the XT2 switched off for it not to force the external storage option.
- Has liked: 398 times
- Been liked: 862 times
Thanks @turbo19 .
I understand the need for clearing everything out and starting from scratch. This time if I scan the qr code, that links to the storage without the question. So I avoided the qr code method.
With this latest Tread 2.09.63 ? Whenever I managed to get the orange buttons to opt to store data or "maybe", nothing happened when I chose 'maybe' and display for weather on the XT2 demanded that Tread was connected.
I must have missed something - but it was a clean install of Tread each time along with a reset explore database and a hard shut down and power up of the XT2.
As I said it used to work. It was the way I intended to use it.
I'll give it a few more tries checking against what you did. I'll be back.
I think that I forgot about the Master reset being necessary.
XT2 is currently throwing a wobbler - taking ages to boot up - repeated progress bar. I've rolled it back to v4.80 and it is now re-installlng 5.40
A little while later.
Many thanks @turbo19. It was the Master reset that was required. Stupid thing is that I knew about that. I remember it becoming a necessity on the XT1 after a software update. Prior to that a simple reset of the Explore database and a restart was all that was necessary.
But then forgot. Right - I'd better go back and correct my ramblings above !! Not to hide it, but to remove the incorrect information. Please keep your quote of it in your post. I'll refer my post to it. It's a useful reminder that I don't get it right every time !!
- Has liked: 2 times
- Been liked: 9 times
Copying maps to the PC also works with XT2.
For a Windows PC you might need an older Garmin Express version like Garmin Express 7.23 ! With version 7.24 there is unfortunately no such function (anymore).
Here, however, it is not really copied, but apparently what is on the XT2 is downloaded again from the network and then copied to the PC.
ok It works, but it takes time, a lot of time, in some cases more than minutes.
If the XT2 device is almost empty, it works fine, but if you have a lot of routes in your XT2 device, it seems that the XT2 device wants to prepare all the internally stored routes first before you see your XT in your Computer and that takes time.
My experience is from the XT, not the XT2, but it might work the same. The startup time increases dramatically with the nr. of Saved Locations/Favourites. The nr. of routes/tracks is less important.proofresistant wrote: ↑Fri Feb 21, 2025 7:11 pm it seems that the XT2 device wants to prepare all the internally stored routes first before you see your XT in your Computer and that takes time.
This might have something to do with the fact that Saved Waypoints / Favourites are stripped out of the gpx file and reorganised in the XT / XT2 - either on tranefer or on Import. I forget which - I think on transfer.
The same applies to tracks if you have them in your gpx files. They are removed and stored somewhere on the XT1/2. I don't know where.
Typically I empty my Zumo before any trip. IT makes it easier to find the routes and points that I want. All of my organisation is done in Basecamp.
