BBBike.org map extracts
ianchapp
Has liked: 6 times
Post by ianchapp »
Since the demise of openstreetmap.nl, I've been trying BBBike.org to get Garmin maps of more obscure areas, in this case, Morocco.
https://extract.bbbike.org/
BBBike.org works brilliantly, except that I have the choice of Latin1 or UTF-8 character sets. I suspect I need UTF-8 (maybe as some Arabic characters?) but unfortuantely when I start my Zumo XT with a UTF-8 IMG file, I get a message that the file is corrupt and unusable.
So Latin1 works, but most place names are appended with a large number of ????? question marks etc, which is extremely annoying!
Anyone have any experience or suggestions?
This issue is hinted at, halfway down this page in bold text. But no solution!
https://extract.bbbike.org/garmin.html
Jim1348
Has liked: 7 times
Re: BBBike.org map extracts
Post by Jim1348 »
As is often the case, when I am looking for other things online, I run across something that I was looking for in the past. I think the reason you were getting the message: Maps Are Corrupt And Cannot Be Used is because you added a map in UTF-8. In retrospect, perhaps you should have used maps in Latin-1 format.
