Downloading latest map to basecamp
- Been liked: 1 time
Re: Downloading latest map to basecamp
As said before there are 4 maps in garmin map folder in library,application support!
- Has liked: 120 times
- Been liked: 120 times
Right, so if one of them is the one you were trying to download, that download may be corrupt. So delete it and start over downloading to your Mac.Neill11232 wrote: ↑Wed Mar 19, 2025 10:59 pm As said before there are 4 maps in garmin map folder in library,application support!
I will try it out today,but, I was actually trying to downloading the map on my device, which is in this folder,not in the long digit form as the other maps are,but as 2026.10. I think I have removed it before,at least in the finder basecamp section,but not in the garmin library,and it made no difference. This is why I was asking if there was a way to load one of the maps in the garmin library,to see if any of the maps will show up on basecamp!
Your initial post seemed to indicate you were trying to download it from your device hence my initial comment. If you're trying to download it using Express and it's failing see this Garmin FAQNeill11232 wrote: ↑Wed Mar 19, 2025 10:21 pm And this where I came in,I can't download the map on my device to my computer using garmin Express,it stops 2.9% into dowload! Which is why I ask if it's possuble to install one of the maps in library,to basecamp?
https://support.garmin.com/en-GB/?faq=G ... C0ULxHR2T6
In order to download it from my device,I have to use garmin express,it's the only way to do it! There was no problem with express to device,the problem is with downloading to basecamp!
Iremoved all the maps in garmin folder, and basecamp plist,but still no joy in downloading map to basecamp
I'm pretty much out of ideas. Have you done the steps in the Garmin FAQ sussamb linked to above?
Because downloading to your GPS worked, we can eliminate Internet issues, so the problem must be on your Mac. Re-installing Express per the FAQ would be worth trying. Also, you could create a new user account on your Mac, install fresh copies of Express and Basecamp, and try again.
Having done as advised,the only difference was the error comes at 1.8% ather thsn 2.9 % previously.
Thanks to all that helped,but,managed to sort out issue and have map installed on my computer!
- Has liked: 71 times
- Been liked: 191 times
Others might have this problem. Can you tell us just how you corrected the issue?Neill11232 wrote: ↑Sat Mar 22, 2025 12:28 pm Thanks to all that helped,but,managed to sort out issue and have map installed on my computer!
