Two Garmin Accounts
dermothalcyon
Two Garmin Accounts
I noticed that I have two Garmin accounts. It looks like that may be causing problems with me using Garmin Explore. Do I need to contact Garmin to have them merge or delete one account? Or, is it something I can do?
- twowheelstom
- Has liked: 146 times
- Been liked: 54 times
Re: Two Garmin Accounts
Garmin might be able to merge the two accounts for you
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
You can log onto one account and get into your account management, get hold of your data and ask Garmin to delete your data and your account.
You can also download or request all of your data in different subsections. Eg you can request all of your history with product support.
https://www.garmin.com/en-GB/account/datamanagement/
You'll need to sign on before you can access that page - or just follow the links.
