No direction sounds from 550
Has liked: 426 times
Been liked: 930 times
Re: No direction sounds from 550
The 550 could play music. There was another cheaper variant (was it 350?? ) that didn't gave the mp3 player. Memory might have that wrong.
wks
Has liked: 26 times
Post by wks »
Correct remembered that it has to be wired ( used to have wired ear plugs) or a Bluetooth dongle.
I only ever used wired stuff with my 550. I don't recall whether or not bluetooth was an option in those days.
Whatever, it had an mp3 player.
24387811rct
Post by 24387811rct »
JfHeaath. First thank you for "the honourable gentleman" part. :oops:
I was actually on a route i had installed into the 550 (one I already knew), and was receiving no directions at all (do you wish to go to start point? etc). Recalculation was on, only one map being used, and Zumo connected only to bluetooth headset.
Problem is beyond my understanding. Even did a factory reset (no joy). Think 550 has gone to the satnav graveyard in the sky. :)
You checked the volume mixer on the 550, I assume ?
24387811rct
Yes, both volume settings at 100 per cent.
Uk ? Where (ish)
24387811rct
I'm in Central Scotland.
