Zumo 660 - Lost PIN
Re: Zumo 660 - Lost PIN
For all of the Zumos that I have at home, there is a pre-boot menu which you access by pressing a sequence of power button.
One of the options is to roll back the software to a previous version. But this is for the 590, 595, XT and XT2. The Pin facility i don't recall using on any of those, so I cannot say whether reinstalling system software would solve the PIN problem.
Nor do I know whether Garmin Express will re-install the software.
The 660 was a very different beast from the later models. I took very few notes on how the 660 behaved. Someone on here may know. I'll see if I can locate anything.
Edit....
The link below describes how to enter pre boot menu for various devices including the Zumo 660. It may also have other information.
But as I said, even if you can get back to a previous software version, there is no guarantee that it will reset the PIN. I simply do not know the answer to that
http://www.poi-factory.com/node/48270
Rens
Australia
Post by Rens »
Thanks so much for your suggestion.
I tried the following, as per the website:
Models zumo: 660
1. Turn off the navigator.
2. Press the LOWER left corner of the screen .
3. Turn on the navigator still holding the lower left corner of the screen + power button.
All that did was recalibration, after chasing a button around the screen.
This is proving to be a curly one indeed.
raesewell
Been liked: 20 times
Post by raesewell »
I don't know if this will work but it costs nothing to try, back in the good old bad old days when crooks would steal car radios there was a trick of putting the radio in a freezer overnight that would clear the pin code. It might be worth a try.
Rens
Australia
Post by Rens »
Mate, fantastic!
Into the freezer it goes :lol:
Rens
Australia
Post by Rens »
Well gentlemen, the enigma has been solved!
The previous owner remembered changing the PIN code. It works with the updated code. Hooray.
Now it's time for a stiff drink :roll:
raesewell
Post by raesewell »
Glad you got it sorted. some people ie: the previous owner are not fit to be let out on their own :lol:
Rens
Australia
Post by Rens »
Hmmm. I'm glad I joined the forum nevertheless.
You guys have a wealth of knowledge.
I'll start using the Zumo properly now.
Rens wrote: Tue May 20, 2025 11:24 am Well gentlemen, the enigma has been solved!
Strange as you said it worked previously with that PIN?
raesewell
Post by raesewell »
I don't think he said the PIN had worked for him, unless I read it wrong.
Rens
Australia
Post by Rens »
You're right. I had indeed used it once. But that was several months ago.
I stupidly didn't record the PIN at the time, thinking that I would remember it. A bad mistake!
So I had to ask him again recently. And that's when he gave me the wrong code initially.
But we got there in the end.
