Map data not available/Cannot calculate route
Re: Map data not available/Cannot calculate route
Glad you are all sorted.
Loads of Information in one of the top links to this forum. viewtopic.php?t=1464
(But nothing about loading maps !!)
finerone
Post by finerone »
I’ve been following this thread with interest as I’ve run into a similar issue recently with map routing on the XT. I’m planning a Rome road trip soon through https://gowithguide.com/Italy/rome/guides so I’m keen to get my XT working properly.
Quick tip: make sure your activity profile (like motorcycle vs off-road) matches your map type, routing can fail if they don’t align. Also, has anyone tried a factory reset after reinstalling maps? Curious if that helps.
