Is there a way to search for a phrase?
Need help with the forum? or got some forum feedback? Please use this section.
I am trying to figure out if there is a way to search for a phrase. Enclosing in quotes doesn't work and I don't see such an option in the advanced search function. Am I missing anything?
Re: Is there a way to search for a phrase?
I can usually find what I using " Search for all terms or use query as entered", but it does produce some extraneous results.
If I do not find what I want with the built-in search, I use the power of Google by specifying the site in my query:
site:zumouserforums.co.uk +"a way to search"
Been liked: 265 times
Just search for what you want
It usually works
