I have tired several times to down load the new version for the Mac and it has failed to download properly every time. Will keep trying and update this topic as I do.
Rebooted the computer, cleared all history, tried again, download still failed. I did update the version that runs in Windows 7 (running on the Mac via VMware). It worked fine. Not sure of the download issue with the Mac version.
Garmin Express Mac Update
- Has liked: 29 times
- Been liked: 39 times
Re: Garmin Express Mac Update
Just tried to update Garmin Express again and the installation failed again. Different internet connection, different location. So, i do not know what the issue is. Garmin express still works but the Mac version on my computer cannot be updated.
It looks like I am experiencing the same issue. I am running Garmin Express 6.14.0.0 on Mojave 10.14.5. When I try to manually update from within Garmin Express I get an "update failed" error.
I will have to check with my iMac which is not running Mojave and see what happens. I am running 10.14.5 on my MacBook Air.
Ok, just went to the Garmin Express website and downloaded the new version. It was saved in my downloads folder. I then installed and it now says I have version 6.14.1.0. I have not verified it works. But...
So, the issue appears to be with the Garmin Express download function in the program.
