Has liked: 39 times
Been liked: 97 times
jfheath wrote: Sat Jan 17, 2026 8:29 am ... but do not give permission to store data or to synch. That allows data - weather, traffic, up-ahead, fuel on route with prices etc.
@jfheath ,
Honestly, I don't think I'm the only one who, as has been mentioned many times in previous posts, mainly wants to use the Tread app to wirelessly transfer gpx content to the zumo XT2.
Other data such as “weather, traffic, up-ahead, fuel on route with prices” are of only marginal interest to me, if any.
(Weather only works for the past anyway, I don't have traffic on the small roads I travel on, and when I need to refuel, I usually use the gas stations that are already on the map when I'm on motorcycle tours).
The Tread app should only do what i (may some one else) need it to do.
  • My priority 1 – Transfer routes (wirelessly) to the navigation system.
      Priority 2 – Share routes with other tour participants.
        Priority 3 – Overview of routes.
          Priority 4 – Edit (correct) routes, possibly also plan them.
            Priority 0 – The other, sometimes rather questionable additional “features.”
          jfheath wrote: Sat Jan 17, 2026 8:29 am But you have to transfer routes using the SD card or by USB cable. Best to store on the SD card with the XT2.
          There is no question that using USB is currently the best and most reliable solution.
          It's no surprise that I like TripManager so highly.
          Nevertheless, I'm not giving up hope on “wireless” as the state of the art.
          proofresistant wrote: Sat Jan 17, 2026 6:08 pm Other data such as “weather, traffic, up-ahead, fuel on route with prices” are of only marginal interest to me, if any.
          I was just saying what is and what isn’t available, rather than expressing a preference. Ie it is possible to link the tread app on the phone without it synching your routes, and changing them. You cannot disable synch once it is installed, but you can set it up without enabling synch. But in order to do that you have to reset the XT2 AND delete the Tread app from your phone, and then reinstall and relink.
          I usually add comments like that for people coming across posts using a search engine, or using the search feature, or just being alerted to a new post - so that they don’t get the impression that there are only two options: With Tread or without Tread. There is a third - with tread, but without synch.
          The weather data can be seen as an animated image eg of rain moving across a map presumably from recent satellite images.
          But weather display is not restricted to historical data It can also show forecast data as symbols eg in an app that is shown on the right hand side of a landscape screen.
          Or as a day-today symbol chart for the week .
          Limited, but it it is there.
          I quite liked the Wireless transfer with the XT1 and the Garmin Drive App. Drive carried out similar functions to the Tread app with the XT2 - Ie it managed the data flow for weather, traffic, etc, it enabled synchronisation of routes from the Explore database - the same one that Tread uses, it allowed wireless transfer. You could set it up so that synch was not allowed, but the other two were.
          So I could plan a route on my computer, export it as a gpx file and email it to my phone. The drive app would pick it up and send it to the XT1. Brilliant. It placed the gpx file in Internal Storage in the GPX folder. From there the data could be imported. I used that a lot primarily because it saved the wait for a usb connection, and it saved wear and tear on the USB socket.
          I do miss that capability, but when I found out more about the transfer / import process in the XT2, I wouldn’t use it even if it was provided.
          That is because the XT2 treats the gpx files in internal storage as its own work areas. Once imported, certain data is removed from the file and the file is effectively resaved without it. Example. You might have noticed that tracks and waypoints are made available in their respective apps, without having to import them ? But the track data is removed from the gpx files when that happens - so that data is lost. You cannot import it manually if you accidentally delete the track from the Zumo screen. This does not happen if the data is put on the SD card. The gpx file remains intact, but tracks and waypoints have to be imported manually.
          Also - routes that come from GPX files and placed on the XTs are all regarded as imported, regardless of the software that created them. They have to be converted to .trip files and that conversion process adjusts and renames route points. They are also susceptible to RUT behaviour if the Zumo recalculates the route. The latter is prevented simply by using the XT2’s copy facility, and using the copied route.
          But the best way to get round the problems is to use Trip Manager, and the only way that can work is by having access to the .System/trip folder.
          And that needs a USB cable.
          Wenzudeg
          Has liked: 24 times
          Been liked: 3 times
          Malta
          Post by Wenzudeg »
          @proofresistant We're exactly in the same situation! I have your same priorities from the Tread app, maybe even less because I ride solo so Priority number 2 may not be on my list.
          Priority 1: Plan, edit and store routes/tracks/waypoints (would be great if with downloadable offline maps but would accept online only planning, just like Komoot app for hiking) in Basecamp(ish) way (would also accept Garmin to call Folders as Collections from now on) with an overview of all routes/tracks/waypoints when highlighting Folder/Collection (with eye icon toggle maybe?).
          Priority 2: transfer via BT of Folder/collection or individual routes/tracks/waypoints OF MY CHOICE to device connected to Tread account. Would accept some recalculation on the device as long as all Viapoints and Shaping points are respected. If all points are respected and route still different from Tread app (should not be if same algorithm chosen) I would accept to go back on Tread app to redraw and insert Via/Shaping and sync back new route to device.
          Priority 3: Garmin uses SAME vocabulary/names at least across apps and devices for the same intended use: Collections OR Folders, Uncategorized OR Unlisted etc.
          Priority 4: Tread app, or at least a web-based version of it, made available for desktop users with an account log in that syncs with Tread app on smartphone/tablet. Other much smaller apps do it: Komoot, Wikiloc, Gaia and a whole lot of others.
          Priority 0: Option in Tread app to go live with traffic/weather/road closures info pushed to device via BT and recalc algorithm to include them if recalc is prompted. This should be an option with a clear on/off toggle so that BT connection may be kept switched on.
          Ok... wake me up from my dream! :)
          Has liked: 39 times
          jfheath wrote: Sun Jan 18, 2026 6:05 am ... I was just saying what is and what isn’t available, rather than expressing a preference. ...
          Hi @jfheath, factually speaking, you are (as almost always) correct in what you write :!:
          But then, at least I interpreted this thread "Latest XT2/Tread software version" as announcing that there are new versions available and what has changed with them.
          Above all, however, I interpreted it also as announcing which eagerly awaited solutions to problems are available.
          Here, I “merely” wanted to point out that the fundamental problems I have been observing for years still have not been resolved.
          Problems with seemingly endless synchronization.
          Problems with duplicate trip files.
          (Very)
          sluggish use of the navigation Device while synchronization is in progress in the background.
          And last but not least, shifted shaping points, some of which are relevant for route planning.
          I think others here have also been waiting a long time for improvements.
          Which “standard” functions are still available could perhaps be better explained in another “functions or highlights” thread, some of which are relevant to route planning. Weather, for example.
          jfheath wrote: Sun Jan 18, 2026 6:05 am But weather ...
          Limited, but it it is there. ...
          ... Limited, but it is there. ...” (Limited sums up my experience very well here) and what I miss most, I already mentioned in a thread created specifically for this purpose :idea: Weather radar shows the past instead of the future (https://zumouserforums.co.uk/viewtopic.php?t=3564)
          I trying no offense, I look forward to more interesting discussions here in the forum :arrow: :!: :) :?: :geek:
          And I'm looking forward also, to seeing a Tread app version that may is useful (for me) at some time in the future ;-)
          turbo19
          Has liked: 193 times
          Been liked: 47 times
          Andorra
          Post by turbo19 »
          proofresistant wrote: Sun Jan 18, 2026 12:15 pm
          (Very)
          I completely agree with @proofresistant ,
          I've done some tests with everything synchronized, and I think Garmin's idea with the Tread app isn't bad, but...
          1- The problem of breaking routes created outside of Tread App is unforgivable. I don't think it will be fixed, as @jfheath rightly says.
          2- It should have a PC option where it would be easier to draw than on a mobile phone or tablet.
          3- The only way I see the entire Tread app/XT2 or Tread 2 ecosystem working is by saving everything as tracks, syncing those tracks, and converting them into routes. This means losing any option to manage routes the way we like, with waypoints and stops that provide the time. It's a shame, but it seems to have been designed for this use.
          After testing a Tread 2 GPS for a few weeks, I've found that its processor is better than the XT2's—faster, with better synchronization, and the map zoom is incredibly quicker.
          I understand that the upcoming XT3 will perform like the Tread 2, or even better. The question is whether Garmin will improve the external route management or if the entire Tread App system will remain unchanged. Which would be another failure.
          Lanso
          Been liked: 16 times
          Belgium
          Post by Lanso »
          Sadly i've resorted to just that.
          I hate having to use usb/sd to transfer things, as we're not in the early 2000's anymore.
          And i often plan my routes on the spot.
          So i gave up and just import tracks & poi's trough Tread. Convert them to Routes on the XT2.
          And then make a collection for the entire route.
          Bike: BMW R1200RS 130.000km
          Has liked: 39 times
          @Lanso , @turbo19
          I have had a similar experience too.
          As far as I have observed as well, the only reliable workflow for using the Tread app, i saw without any problems seems to be to transfer tracks and/or waypoints to the navigation device and then convert the tracks into a route on the device.
          However, it should also be noted that routes with shaping points that were additionally transferred to the device via USB or SD card will probably (or likely) cause synchronization problems again.
          Ergo, if you use the Tread app, may it is best to completely avoid shaping points (i.e., may via) in routes.
          Personally, however, I need shaping points so much that I don't want to do without them and instead avoid using the Tread app (for route synchronization).
          I also agree with @turbo19 that the Tread 2 works noticeably smoother and performs better than the zumo XT2. So, from my point of view, I would go so far as to say that the Tread 2 is the better zumo overall.
          It remains to be seen what the future holds for the Tread app, although I share @jfheath's opinion may we shouldn't expect too much.
          Then it remains to be seen also, what new zumos will bring and when. I'm curious, even though I don't want to invest any more in Garmin based on my experiences.
          Francis
          Has liked: 13 times
          Been liked: 18 times
          Czech Republic
          Post by Francis »
          jfheath wrote: Sun Jan 18, 2026 6:05 am The weather data can be seen as an animated image eg of rain moving across a map presumably from recent satellite images.
          IMHO viewing only history is OK, we can't see into the future and predictions are not 100% reliable. Let everyone evaluate the trend for themselves.
          BMW R1200 ST
          Spot on. I hate going out in wet weather, but it doesn't bother me if it starts raining when I am out. I always have full waterproof textile gear on all of the time anyway. But - if you don't know where you're going, any road will take you there - and I will sometimes look at the clouds to see which way the wind is blowing and head out in the direction which looks brightest.
          I love that - Thank you @jfheath
