Can I use a 128 GB SD card
- twowheelstom
- Has liked: 146 times
- Been liked: 54 times
For my Zumo 396,
can I format a new 128 GB SD card and format it FAT32 with Allocation Unit Size: 65536 ?
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
- Has liked: 119 times
- Been liked: 267 times
Re: Can I use a 128 GB SD card
I've never had any luck formatting a card and then inserting it. For the last few, I installed it new and let the unit format it. Dunno if the 396 will do that but the 595 and XT1 do.
FWIW, I have a 64 GB card in my XT, formatted FAT32 of course. I don't recall what I did for allocation units but I know I would have chosen significantly smaller than 65536 if I had the choice. An exFAT format would default to 8096 which would be my choice for FAT32 although if I planned to put a lot of music files on it I would consider doubling that since those files are much larger than gpx files. As for the 396 with a 64GB card, IDK. My sense is that not much has changed with SD cards in Garmin device for a long time since they still require FAT32 formatting. If you already have a 64 GB card then there is no harm in trying it.
- twowheelstom
Maybe I should format a 128gb cards allocation size half that 65536 ?Peobody wrote: Sat Mar 07, 2026 2:08 pm but I know I would have chosen significantly smaller than 65536 if I had the choice.
so allocate the 128 gb card to size 32768 ?
since 4 x 32 = 128 gb
I don't see anything greater than selecting the max 32768 allocation size on this fat32guiformat.exe free download program i downloaded last nite
I think using a 128 gb sd card is probably the maximum size card that can be used in a 396 for fat32 formatting
dunno,
wow I hate math, failed it all thru school since grade 1 lol
my poor Teachers lol
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
- twowheelstom
ya from what I was reading, all of the Garmin Zumo's including XT2 and XT3's all require the maximum file size to be 4gb or less, Garmin requires them all to be FAT32 I thinkPeobody wrote: Sat Mar 07, 2026 2:08 pm My sense is that not much has changed with SD cards in Garmin device for a long time since they still require FAT32 formatting.
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
That 4GB file size limit is not a Garmin thing. It is a file size limit of the FAT32 formatting.
Edit: It's a beautiful day in the neighborhood (at least my neighborhood) so I'm suiting up and heading out on a ride.
- twowheelstom
i got that wrong, the max allocation size showing on that fat32 format program is 65536twowheelstom wrote: Sat Mar 07, 2026 2:30 pm should format a 128gb cards allocation size half that 65536 ?
told ya that I failed math lol
ignore all my math, i got it all wrong,
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
Does it give you choices of smaller sizes?twowheelstom wrote: Sat Mar 07, 2026 3:15 pm i got that wrong, the max allocation size showing on that fat32 format program is 65536
FWIW, I used the free version of AOMEI Partition Assistant.
- twowheelstom
Yes, cluster allocation size choices are:Peobody wrote: Sat Mar 07, 2026 9:51 pmDoes it give you choices of smaller sizes?twowheelstom wrote: Sat Mar 07, 2026 3:15 pm i got that wrong, the max allocation size showing on that fat32 format program is 65536
guiformat.exe
512
1024
2048
4096
8192
16384
32768
65536
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
