There are lots of ways to 'send to' in TripManager.
Could you provide more info what you do exactly?
Introducing TripManager
giuseppe66
- Has liked: 30 times
- Been liked: 9 times
Re: Introducing TripManager
Yes, sorry, i set TRIPS, TRACKS and COMPLETE ROUTESFrankB wrote: Tue Apr 14, 2026 2:35 pm There are lots of ways to 'send to' in TripManager.
I dont have the answer yet, can you post the GPX here, or send me a PM?
Using both Tracks and Complete Routes is not needed, if there are tracks in the GPX.
My guess is that there are no tracks in the GPX.
Tripmanager can generate a track from a route, but only if the route is from Basecamp. For MRA you need to export GPX 1.1 Route+Track.
You are using Trk2Rt, how exactly?
giuseppe66
i've send you a private messages with 2 files. I export from MRA in 1.1 format and use default option in Trk2Rt, no custom option. ThanksFrankB wrote: Tue Apr 14, 2026 2:57 pm I dont have the answer yet, can you post the GPX here, or send me a PM?
