Help from Anyone Buying an XT3
twowheelstom
Has liked: 146 times
Been liked: 54 times
Re: Help from Anyone Buying an XT3
Post by twowheelstom »
Francis wrote: Sun Feb 22, 2026 5:07 pm The 5-pin cable in the kit has the Tread 2 and does not require additional costs Why does Garmin supply it with the Tread 2 but not with the XT3?
how much additional cost is this 5-pin cable?
Zumo 396
1994 Yamaha 250
twowheelstom
Garmin High-Current Power Cable (010-13087-19 / 010-13087-01): Specifically for Tread series, often listed around $79.99 - $89.99 CAD.
Zumo 396
1994 Yamaha 250
twowheelstom wrote: Fri Feb 27, 2026 10:38 am Garmin High-Current Power Cable (010-13087-19 / 010-13087-01): Specifically for Tread series, often listed around $79.99 - $89.99 CAD.
But not compatible with the XT2 or XT3. The replacement cable with the new cradle is
https://www.garmin.com/en-GB/p/1933581/pn/010-13985-00/
patrickg450
Post by patrickg450 »
Question: Can you link the in reach with the new XT3? I read you can on the XT2.
