The Zumo XT screen works great in sunlight
lucaspalm
Post by lucaspalm »
One of my favorite things about the Zumo XT is how readable the screen stays during bright daytime rides.
I used to rely on a phone for navigation, but strong sunlight often made the map difficult to see. The XT is noticeably clearer, and that makes a huge difference on longer touring trips.
Re: The Zumo XT screen works great in sunlight
It certainly does! I put a cheap matte plastic phone screen protector on mine. Doesn't affect screen visibility much but it does cut down on the glare and sun reflection.
rbentnail wrote: Mon May 18, 2026 9:54 am It certainly does! I put a cheap matte plastic phone screen protector on mine. Doesn't affect screen visibility much but it does cut down on the glare and sun reflection.
I did the same, though mine was less effective than what @rbentnail reports. Reflection from my hi-viz jacket and helmet can be particularly bad.
I encountered some ghosting issues to which Garmin support responded with recommending removal of the film, which I did. It had been on for many thousands of miles so I don't think it was the cause of the ghosting. I haven't experienced any ghosting since though so who knows.
The only ghosting I get is in the rain, and it does it with or without the film.
