Zumo 665 Hidden Files
carolinarider09
Has liked: 30 times
Been liked: 39 times
Post by carolinarider09 »
Somewhere along the line, either I made a mistake or I don't understand how the internal memory works on the 665.
I was looking at the information from a previous post on improving my Zumo's performance and tried to find the map files on the 665's main memory. They are not there. However, the available memory on the 665 i less than 500 mb (working on memory don't have it with me).
So, my question. Has anyone had this issue and if so, how was it resolved?
Has liked: 382 times
Been liked: 384 times
Re: Zumo 665 Hidden Files
If you can't find them then they are in the hidden .system directory.
carolinarider09
Has liked: 30 times
I will look.
