NT2020.1
Has liked: 104 times
Been liked: 221 times
Re: NT2020.1
Davemyers wrote: Tue Aug 13, 2019 8:27 pm Well that didn't work either.
This time I’ve formatted the sd card, so let’s see what happens next
Garmin's kind of goofy with SD card formatting. I never had any luck doing it on my computer then installing it in the device. I was always better off buying a new card, putting it in right from the package and let the device do its magic on its own. Yours may be different obviously but the 595 recognizes and asks if you want to format it.
Has liked: 344 times
Been liked: 369 times
Re: NT2020.1
Hope you formatted it FAT32?
If you have the map on your PC MapSource can send the map to your device.
Davemyers
Falkland Islands
Re: NT2020.1
Post by Davemyers »
Finally!
Yes I reformatted it in Fat32 (whatever that is) but I did it whilst installed in the 660 and hooked up to the PC
Ran it overnight, and this time it’s all working.
What a performance, I’ve never had this kind of problem in 20 years of owning Garmins.
Re: NT2020.1
Me neither and still haven't :lol:
Glad you got it working :D
Davemyers
Falkland Islands
Re: NT2020.1
Post by Davemyers »
Thanks it’s really had me scratching my head. I’ll know next time.
Now I’m playing about with the Camper 760 to see if I can get it to accept my POI file in the main options box rather than just in the favourites slot.
I think I know what I want it to do but I’m being careful not to undo something I need :roll:
