Hello. The Zumo will not power up.
I have swopped the battery for a known good one, this one also is charged and works in the other Zumo as well. Won’t power up.
I have put the unit into a known good bike cradle and it will not power up.
I have used usb lead into the PC and it will not light up or communicate in any way.
I’m assuming it’s snafu , but is there anything else that can be tried?
Zumo 660 will not power up
- Has liked: 28 times
- Been liked: 38 times
Re: Zumo 660 will not power up
I have never experienced that issue with my 660. So, the only suggestion I would make is that repair might be a possibility from the Palm Doctor. I had my 550 repaired by him and it still works like new.
http://www.palmdr.com/cart/
Thanks, but I’m in the UK (the Falklands flag is just a reminder to the Argies to keep out! )
Any other options?
Any other options?
- Moose
- Has liked: 3 times
- Been liked: 21 times
did you put your finger solidly on the bottom right of the screen while turning on the power just keep your finger there till it tries to boot maybe
