Hi
I came across the board by accident. Having read through many of the posts, there are a lot of answers that I can provide - so I'll post messages to some of the more recent ones to see if members are still listening in.
In particular I can help with Zumo 590 and others Zumos with the Trip Planner App, Zumos 550 and 660. Also use of Basecamp, Mapsource and planning routes. Extensive research into why the later Zumos do not behave as you might expect, and use of the satnav with wired Autocom and Bluetooth.
Introduction
Introduction
- Site Admin
- Has liked: 438 times
- Been liked: 266 times
- kernowing
- Has liked: 135 times
- Been liked: 61 times
Re: Introduction
Welcome to the forum. I'm sure your knowledge will be put to the test soon enough
I've just bought an Autocom system that I'll be using alongside my 660.
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
Re: Introduction
Thanks. I have a SuperProAVI (one of the latter wired analogue units) that i used with my 660 for a good number of years. A good combination.kernowing wrote: Sat Oct 19, 2019 9:23 pm Welcome to the forum. I'm sure your knowledge will be put to the test soon enough![]()
