Basecamp 4.8.7.0 Avaialble
carolinarider09
Has liked: 29 times
Been liked: 39 times
Post by carolinarider09 »
Just downloaded this version. Have not verified it yet. The program does open up though.
midlife
Re: Basecamp 4.8.7.0 Avaialble
Post by midlife »
I made the mistake of updating to 4.8.7 on my applemac, since then I only get a 1/4 screen in 3d. Garmin told me to uninstall and had to uninstall basecamp app, then go to library and uninstall com.garmin.basecamp.plist and then re-install.
I now have lost all my routes and waypoints and the 3d view still is faulty.
be careful and dont do what Garmin suggest bloody useless
Graham
will try not to piss too many people off
Has liked: 372 times
Been liked: 383 times
I think I replied to you on another forum, but an uninstall and reinstall of BC doesn't delete databases. However if you'd set a location other than the default you'll need to reselect the correct database.
