ok, I need some windows help here. I got a new PC like 4 months ago. I have BC up and running, I want to back up all my tracks and whatnot. I did a search for the folder BC defaults to for saving...........cant seem to find it.
Windows 10
- Has liked: 106 times
- Been liked: 63 times
Re: Windows 10
Somewhere in the "C" drive on my laptop there's a folder called
"Roaming" in it there's a sub folder,
"Garmin" in it there's a sub folder,
"Basecamp" in it there's a sub folder,
"Database" in it there's a sub folder,
"4.6" which has the data needed to swap from one PC to another, which I used to do when I had a laptop for home use, and one I took away with me.
I strongly suspect that the roaming folder is a hidden one.
Re: Windows 10
When I changed pc I did a “backup” on old pc then a restore from that file on new.
The advantage was that all my bought is maps were included in the backup without having to connect a device
Re: Windows 10
Did a search for Garmin.........found my old tracks from Mapsource.
FInally found it, GARMIN ---> BC---> Data base---> 4.7--->
there is 2 AllData(s)
.gdb and a gdb.bak
But I cannot navigate to it or see the path to get to the folder
.gdb and a gdb.bak
- Has liked: 369 times
- Been liked: 789 times
Re: Windows 10
Note that you can have as many databases as you want. They all get saved in the same general location. Switch from one to the other from within Basecamp. I put details in the Zumo And Basecamp document I posted a little while back. I'm currently modifying it to include specifics for Zumo 595. When I get to my Pc, I'll post the relevant information here.
Nb I have no problem accessing the database location from within Windows 10. I always have it set to show hidden files though. I didn't think that they were hidden. Most of them are ones that I have created though. I'll check.
