Duplicating internal drive on zumo 396
CRracer
Has liked: 12 times
Been liked: 5 times
Post by CRracer »
Figured before I did anything on my 396, I'd copy the internal drive contents.
As it came new, it showed it had a little over 4gb used. Selecting all contents in the drive only showed 259mb. I noticed no map files anywhere.
Then I just selected the internal drive itself and doing a copy showed it was copying the entire 4gb of data, and showed the large map file names as they were being copied, but they actually don't show visible, either on internal drive or in the folder that 4gb of data was copied too.
Yes, file manager was set to show hidden files.
Is there something on the newer zumos preventing the map files from showing up as they do on my two older ones?
New map names being copied were the same names as on my older units.
Has liked: 371 times
Been liked: 380 times
Re: Duplicating internal drive on zumo 396
Also need to set to show system files, the folder you're not seeing contains the large map files etc, it's named .system
mpenner
Post by mpenner »
JaVaWa device manager is very handy for exactly what you are try to do
CRracer
Has liked: 12 times
Been liked: 5 times
Post by CRracer »
sussamb wrote: Fri May 01, 2020 6:17 am Also need to set to show system files, the folder you're not seeing contains the large map files etc, it's named .system
That got it!
Thanks!
CRracer
Has liked: 12 times
Been liked: 5 times
Post by CRracer »
mpenner wrote: Fri May 01, 2020 1:28 pm JaVaWa device manager is very handy for exactly what you are try to do
I'll check that out
CRracer
Has liked: 12 times
Been liked: 5 times
Post by CRracer »
Is there a way to turn off, once a for all, the user agreement that pops up every time I turn the unit on?
It's right before the warning about not playing with unit while driving.
I seem to hit accept but it comes back next time I turn it on.
CRracer
Has liked: 12 times
Been liked: 5 times
Post by CRracer »
I've got some IBA routes in my Zumo 550, what's the best way to get them over to the 396?
Routes were created on mapsource years ago.
CRracer wrote: Fri May 01, 2020 2:31 pm Is there a way to turn off, once a for all, the user agreement that pops up every time I turn the unit on?
It should disappear after you've got a satellite lock?
CRracer wrote: Fri May 01, 2020 2:32 pm I've got some IBA routes in my Zumo 550, what's the best way to get them over to the 396?
Routes should be in the file named current.gpx along with all your waypoints etc on your 550. Just copy that file to the GPX folder on your 396. Note though you must rename it to something other than current.gpx
When you then boot your 396 you should see the routes. Be sure once you do to delete the gpx file you renamed.
CRracer
Has liked: 12 times
Been liked: 5 times
Post by CRracer »
sussamb wrote: Fri May 01, 2020 3:06 pm
Hmm, I'll give it some time. I know I got a satellite lock yesterday evening, it was previously showing Florida, took a couple minutes before it showed my current location and time.
