When I connect the XT via USB, I see the lightning bolt through the battery indicating that the battery is charging. When I connect to 12V via the mounting bracket I do not see the lightning bolt. However, the GPS does turn on when I connect the mounting bracket to 12v indicating to me it is recognizing the power.
Should the battery be charging?
Does yours exhibit this behavior?
Bob
Charging while in mounting bracket?
- simoncrewe
- Has liked: 46 times
- Been liked: 37 times
Re: Charging while in mounting bracket?
Just been out to the garage & put the XT on my KTM and I get the lightening bolt on the battery symbol.
The unit also fires up the minute it goes in to the mount.
- simoncrewe
Might be worth having a look at the pins in the power cable, there have been a number of reports of them going bad/breaking.
Thanks, this is with 2 different new version mounts and all looks fine.
The odd thing is that the unit powers on when connected, but no lightning bolt and the unit eventually dies while riding. Not getting power.
I cut off the Garmin fuse attached to the harness because I connected directly to an port on my handlbars that is already fused if that matters.
I verified +12V on the pins. The third pin down has +12 and the bottom pin is GND.
Bob
Bob
That was the problem. I was told by support that it was just a fuse and I didnt need that since I was connecting to a fused connector. Put the box back and now OK.
I cut the black box (transformer)off mine and soldered on a USB plug to go to the USB port works fine
- Has liked: 5 times
- Been liked: 31 times
That is because a standard USB port supplies 5V of power, not 12...
Cutting off that black box on the XT power cord and wiring it directly to a 12V (i.e. battery tender or cigarette lighter) connection will not work.
