Is there any way to compare routes that are not in the same list folder?
I.e. I’d like to be able to choose 2 or 3 routes that aren’t in the same list folder and have them all “Show on map” without first having to copy them all into one list folder. Possible?
TIA,
Phil
Comparing routes within different list folders?
Phil - Current VP New Sweden BMW Riders, Past President
Voorhees, NJ
Zumo 396 -> SENA 20s EVO
BMW R1200RT
APRILIA Caponord Rally
Voorhees, NJ
BMW R1200RT
Re: Comparing routes within different list folders?
Afraid not, best you can do is see all lists within one folder by selecting the parent folder or all folders by selecting the top folder. You can't select two folders only.
Unless I have misunderstood, all I do is have a subfolder called TEST in which I copy and paste all relevant routes, waypoints, etc. Then after planning I either delete them or use ‘remove them from this folder’ to preserve them elsewhere.
Thanks, suss. Oh well...
That is definitely Something I’d want on a “wish list“ but I understand Basecamp is basically “fully developed “ ... another similar wish is choosing only certain waypoints to grab to put into a new route. Like what can do in Windows, choosing What you want with the <Ctrl > key. I have over 4,000 waypoints in my saved waypoint list. Dragging one at a time is a pia.
Voorhees, NJ
BMW R1200RT
Voorhees, NJ
BMW R1200RT
Well you can group select now and create a route from that selection so you already have what you want, Ctrl + click works in BaseCamp just as in Windows.
