Old Maps
Scarecrow
Been liked: 28 times
Old Maps
Post by Scarecrow »
Hi Folks
This has probably been asked before but I cant find anything on search. :roll:
I have City Navigator Europe NT 2015.40 thru to 2020.30 on my computer
can I delete the older maps say up to 2020.10
to free up space on the computer or will it affect things.
I Hope this makes sense
Cheers
Del
Been liked: 265 times
Re: Old Maps
I delete all the old maps just leaving the current one that I am using :)
Scarecrow
Re: Old Maps
Post by Scarecrow »
Thanks Stu
That helps a lot
It should take my computer out of the red :lol:
khunpaul
Been liked: 5 times
Re: Old Maps
Post by khunpaul »
I always delete maps via the add/remove program app.
Also there is a massive folder called coreservice In ProgramData that seems to remain after update.
I delete after all units have been updated.
Re: Old Maps
Just to clarify this. Express downloads the files required to compile the map in .img format that it then sends to your device. These files are the ones in C:\ProgramData\Garmin\CoreService\Downloads\Map
The files aren't removed by Express and build up over time if you don't delete them. They aren't deleted via Control Panel.
If you elect to install the map to your computer for BaseCamp to use they are stored elsewhere, and can be deleted through Control Panel.
