Bummed to see that others have waited months. I have a long trip planned and really want the GPS to be secured.
I'll quit whining now and suck it up!
All the RAM mounts I've ever had had a handle to undo the extension clamp, I use something like this https://www.ebay.co.uk/itm/A2-STAINLESS ... SwZ2pcbGPP to replace the handle so it's harder for a nasty person to take away the clamp / GPS mount. Quite a bit cheaper than this from RAM https://www.ram-mount.co.uk/7-pinlock%C ... 55aoip04d4
Most people normally mount the TT mounts onto a 'bar' 12mm or flat on a dash / nav tower. They are supplied with 12mm clamps to suit a bar type application. I don't think I have seen one used in connection with a ram mount.Skipper wrote: ↑Mon Jul 06, 2020 5:05 pm I am sure Touratech has is a good lock for the unit, although a bit complicated in its construction
as was the previos one in my opinion.
What I ask myself is if there also is provisions to protect the RAM mount from being unscrewed
which is quite easy otherwise. Can't really find out from the description provided.
