Own typfiles on Zumo xt?
In meny Garmin device you can use own typfiles but not in Zumo xt, someone who has a solution? Garmins topo map are horibble without retyping
- tetyped
- Jäckvik omtypad.jpg (254.78 KiB) Viewed 4306 times
- Garmin original
- ori typfil Jäckvik.jpg (137.97 KiB) Viewed 4306 times
- mzeist
- Has liked: 33 times
- Been liked: 31 times
Re: Own typfiles on Zumo xt?
the XT uses themes not typ files. According to this page: https://www.pinns.co.uk/osm/theme_editor.html the TYPWiz editor can convert typ to themes.
I have not tried this myself yet, I did however edit my themes.
Look for some more info about editing themes in this thread: viewtopic.php?f=48&t=730&p=4641&hilit=themes#p4641
Groet, Marcel.
I want the old time back with typfiles, but thank you for your explanation
- mzeist
I hope you can find out if converted .typ files will work on the XT
would you be willing to share your .typ file from ts post? looks much better than the garmin version!
Groet, Marcel.
Typefiles for various maps are here. Currently not tested on Z-XT....
http://resmark.se/gps/hmrtyp.zip
HMR
On my KTM690E: eTrex, Montana, 276Cx yes, but I mostly use my GPSMAP 278.
In my own car: Nuvi 760, Nuvi 765 but nowadays Camper 760.
In rental cars: Samsung S3 with Garmin Street Pilot.
I have now tested installing own typfiles in maps to be used on Zumo XT.
It works fine. The installation procedure is not different from what you use with other Garmin models. But the map needs to be licensed for the GPS.
Within a few days you can download typfiles for Zumo XT for City Navigator 2021.1 and Swedish Topo PRO V6 from http://resmark.se/gps/hmrtyp.zip
HMR
Yesterday I made new typfiles available. Now tested also on Zumo XT.
HMR
