The PGPSW data does not seem to run exactly the same on my XT as it did on my 595. I have installed it in the same manner as I have always done, would you mind if I clarified a couple of issues with you?Northernlanes wrote: ↑Wed Aug 19, 2020 8:36 pm for me PGPSW speed camera databaae works fine on my XT, as it did on my 550 and 396 before it.
I also have free lifetime PGPSW updates having previously supplied the various yellow speed camera icons on their site., because of the XT's higher def screen these are a little small but I've doubled their size in a image editor (unfortunately these aren't on the PGPSW site)
Have you installed the database on the SD card?
Is it in the 'Garmin folder?
Have you put in in a separate 'POI' folder?
Many thanks
Simon
