Mapsource to Basecamp
Scarecrow
Been liked: 26 times
Post by Scarecrow »
Hi guys
Can i copy a route from MS into BC without any problems
Has liked: 371 times
Been liked: 380 times
Re: Mapsource to Basecamp
Yes, you can even use the normal windows copy and paste commands.
Scarecrow
Post by Scarecrow »
Thanks Sussamb
Do I just paste them into a folder on Basecamp
Or into a list, so click on the folder or list to select it and then paste into the lower left hand pane
Scarecrow
Post by Scarecrow »
Thanks Again Sussamb
