Here a sample sharing route from my phone, whatzapp to google maps to smatphone link at the end to zumo
SHARE ROUTE BY SMARTPHONE LINK
giuseppe66
- Has liked: 30 times
- Been liked: 9 times
- Site Admin
- Has liked: 438 times
- Been liked: 266 times
Re: SHARE ROUTE BY SMARTPHONE LINK
Is that a gpx route or just a location that you have sent to the zumo from the phone?
giuseppe66
is a location. I do not use gpx from phone to Zumo. Copy gpx from computer to Zumo by USB cable. But i can try send by phone by smartlink...for study..and down there is my study
- Site Admin
You can't send gpx to 590/595 via smartlink
This is how I used to do it https://zumouserforums.co.uk/viewtopic.php?f=19&t=610
I now have the XT and its much easier
giuseppe66
if you want share a gpx from your phone to Zumo, for now, you must use a OTG cable usb. With SMARTPHONE LINK old version is possible share a gpx with Zumo (for 595 firmware 4.5 or 4.6) but with update, for now, is possible only by OTG cable or micro sd card reader for phone (cable is more simple, just connect)
- 20201115_204214.jpg (98.95 KiB) Viewed 3536 times
- 20201115_204125.jpg (139.57 KiB) Viewed 3536 times
