Version 7.3.0.0 Released
- Has liked: 13 times
- Been liked: 33 times
Version 7.3.0.0 was released a few days ago.
Michael S.
Trinity, North Carolina
- Has liked: 22 times
- Been liked: 22 times
Re: Version 7.3.0.0 Released
Seems to be a bug in this release. My PC locks up, under certain circumstances when it's running. 100% repeatable, and when Express is closed, the problem goes away.
If I try to send an email - I've tried it with two different mail clients - with an embedded jpg or png, when I click on "send" that mail locks up, followed by the email client, and other programs. It's not possible to end the task on anything that's locked up. Close Express, do exactly the same thing, and all is well.
OK. I've tried it on Windows 7 and 10 and it seems to be ok so far. Maybe a reboot might help if you haven't already tried that?
LOL, about a million times (and not by choice!) till I worked out what was causing the problem. When it does its thing, a hard reboot (thank goodness for backups!) is all you can do.
I agree it's fine on W10 too.
I think it's a memory addressing problem, for what it's worth.
Jim
- twowheelstom
- Has liked: 5 times
- Been liked: 21 times
When I run Express for the 7.3.0.0 update it runs for 10 seconds then I keep getting an Install Failed message on my Windows10, error message says Cannot Install Update on this computer... do I have to plug in my Zumo550 for the Update to work?
2005 Kawasaki 800 cruiser Zumo XT
No, should install without any device connected. Try this FAQ https://support.garmin.com/en-GB/?faq=i ... 0Microsoft.
