Tourtech Locking Garmin Zumo XT Mount
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
Re: Tourtech Locking Garmin Zumo XT Mount
I think you may well be correct for that reason! Sorry for any confusion.
As Ian said you'd need the release lever at the bottom to do that. That would give you an upside down screen.
- Has liked: 3 times
- Been liked: 26 times
a
All fitted .
I was worrying needlessly there's plenty of room for the Key. I've fixed it above the clocks on my existing Kawasaki GPS mount rather than a ram mount.
Still a pity Garmin didn't include some sort of secondary security loop .
All fitted .
- simoncrewe
Before I got my TT mount I just put a self adhesive cable tie mount on the rear of the case & attached a tether.
https://uk.rs-online.com/web/p/cable-ti ... lsrc=aw.ds
