Hi to all
The Zumo stop the vocal instruction.
I check all the parameter, is the same i always used.
I try with the factory reset, and the problem still.
When i change same parameter, random, sometime the vocal instruction restart, but when i power off the device, after the restart, if i put a new destination it say only the first instruction and nothing else.
Sameone have any idea?
Thanks
No vocal instruction
- Site Admin
- Has liked: 424 times
- Been liked: 246 times
- Has liked: 132 times
- Been liked: 109 times
Re: No vocal instruction
Does it have the problem with and without a bluetooth headset, or only on one of these?
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
I have the same problem with my unit, using it in the car on its built in speaker. The unit says ; 'please drive to highlighted route' then nothing.
Has only just started doing this, so I will need to call Garmin.
- simoncrewe
Andrew - I have just spoken to Garmin UK, they have asked me to send them a video of it happening, I get the impression that they know there is an issue.
I would suggest that you contact Garmin also.
