New Firmware
simoncrewe
Has liked: 47 times
Been liked: 38 times
New Firmware
Post by simoncrewe »
Firmware version 5.9 just released, I could not find it on Garmin Express, but available direct on the XT itself.
mzeist
Has liked: 33 times
Been liked: 31 times
Re: New Firmware
Post by mzeist »
Groet, Marcel.
Re: New Firmware
Some nice updates there :)
TripleThreat719
Has liked: 5 times
Re: New Firmware
Post by TripleThreat719 »
Looks like the Group Ride Radio Mount is going to cost an additional $349.99 in order to be able to utilize those features.
Re: New Firmware
Just found that. I thought it was an error. A jump from 2.90 to 5.90 ?
Thats one heck of a lot of development going on in the background.
More testing then. Ho hum .... I wonder if they have fixed .........we'll find out !
Nice to know that they have not abandoned the XT
Been liked: 266 times
Re: New Firmware
jfheath wrote: Wed Mar 10, 2021 8:55 pm Just found that. I thought it was an error. A jump from 2.90 to 5.90 ?
Well the ability to have buttons on the map is a nice feature
I use the skip feature a fair bit when I go wrong :lol:
TripleThreat719
Has liked: 5 times
Re: New Firmware
Just a quick note re: Track Width Feature... If you have previously modified the original garmin.kmtf and created a Thick.kmtf file and are using that theme on your XT, your track widths are modified based on the current theme settings with that new feature. So if you want to use the XT's new Track Width Feature, you may want to switch back to the Garmin Theme, otherwise your track widths will be really thick when selecting the wider or widest settings while using the Thick.kmtf theme.
Milu23771
Been liked: 8 times
Italy
Re: New Firmware
Post by Milu23771 »
After the update, the OSM maps that I had installed to navigate off-road, because in my area the City navigators are very approximate as far as dirt roads are concerned, they are no longer navigable. If I only activate OSM the navi always replies "impossible to calculate the route", whereas before it worked perfectly. Has anyone noticed something like this
Re: New Firmware
"Impossible to calculate" usually crops up when you have two maps for the same area loaded. If you want OSM maps, then disable the CN Europe NTU maps (or whatever ones you use. Having both ticked produces all sorts of funny side effects - including simulator taking you across fields.
Re: New Firmware
Re the New firmaware 5.90
Unsure what some of these things mean :-
Group Radio stuff. Perhaps you need something else connected before anything pops up for that feature to be obvious ?
Save waypoints by clicking on the map has been there since 2.30 It drops a flag, you click on the name and save. Am I missing something ?
Unfortunately two things haven't been fixed.
i) Normal points (not waypoints) created in Basecamp still lose the name that you gave them when transferred to Zumo
ii) Changing a Via Point to a Shaping point still causes the point to relocate and acquire a new name.
My XT went mental, as if keys were being pressed.. Started off being supersensitive, and then started pressing buttons randomly and typing things into any text box that was available. I did 2 cold restarts and a complete system restart before that behaviour stopped.
Anyone else had weird issues ??
