Hi all, hoping your collective wisdom can shed some light.
I have connected my IPhone 11 to my XT and all looked well. Also connected my Sena 10U to my Zumo. When I try and use the phone app on the Zumo to make a call I get the message that ‘phone call support is disabled and I should connect a headset’.
My Zumo shows my IPhone is connected and shows in blue a media connection icon but not the phone icon. I can play media mp3 from Zumo to headset no problems but, despite many attempts, I cannot seem to use the phone call functionality.
Any ideas gratefully received as it’s driving me nuts
Keef
XT / Iphone11 - phone call support disabled
Re: XT / Iphone11 - phone call support disabled
I don't have an Iphone so can't help on that aspect. If you haven't done so already delete all your bluetooth pairings on all devices (ie. phone zumo and headset.) and start fresh.
I know with the android phones the voice dialling stopped working and the workaround was to have the phone unlocked using smartlock, but you still have to unlock the phone once when they have paired.
- Site Admin
- Has liked: 414 times
- Been liked: 229 times
Have you also got the phone connected to the headset?
Delete the pairing between the phone and Sena and only pair the Sena to the XT. That should work.
- Has liked: 1 time
- Been liked: 33 times
I know that when I was attempting to pair my Sena 10 to my XT, I had to pair the XT as a "phone" device(not a media device) on the Sena. Then it appeared as a headset to the XT unit and my phone worked fine thru the XT.
+1 on what others have said about remove all other pairing and start from scratch. BTDT.
