Can't install Maps on PC for BaseCamp with new Zumo XT firmware 5.90
Locked
GeorgeStevens
Post by GeorgeStevens »
Since installing the brand new firmware 5.90 to the Zumo XT the option to install City Navigator maps also on PC for usage with BaseCamp seem's to be gone - only a fresh installation on the unit itself is possible. The whole map administration has been changed and a installation of the maps to quickly access them with BaseCamp without connection of the Zumo XT to the pc is not possible any more.
If this is a bug (some time ago this problem already appeared after a Garmin Express update!), please fix this quickly - but if this is meant to be so, this is i complete no-go for planning some routes on the pc. Even that the Zumo XT has a lot faster access to his onboard maps than the units before, this is no way for working quick and reliable on pre-planned routes. The maps have to be on the pc for this - please change this back...
Has liked: 377 times
Been liked: 383 times
Re: Can't install Maps on PC for BaseCamp with new Zumo XT firmware 5.90
No point asking that here as we have nothing to do with Garmin. If you look through the threads here you'll see this is a known issue and some work arounds are posted. Any queries please post in those threads so we don't have yet another one running. Thanks
Locked
