Garmin Zumo XT OVER HEATING
Erf70
Post by Erf70 »
Hi all I am hoping some one can help, just bought the Garmin zumo xt and when i charge it on the car charge lead the left hand side of the unit gets very hot.
Is this normal as i drive with the charge lead in because i may driving for 4-5 hours at a time.
I have been onto Garmin and i am being asked all sorts of question. Just thought i would people that use it as am waiting for Garmin.
Thanks all Ian
electro_handyman
Been liked: 36 times
Re: Garmin Zumo XT OVER HEATING
Post by electro_handyman »
Well, I'm not sure what your definition of 'hot' is but I have noticed that mine does get very warm when I have it in the bike mount and turned on.
Erf70
Post by Erf70 »
Eletro-handyman cheers for your reply it seems these do heat up when plugged in. Very warm would be a better definition, will keep my eye it. Once again thank you for your reply.
