Dashboard
Scarecrow
Been liked: 24 times
Dashboard
Post by Scarecrow »
I'm pretty sure on my 590 I had the option of arrival time (destination)
however I don't seem to be able to find it on the XT
Any help please
colirv
Has liked: 53 times
Been liked: 41 times
Re: Dashboard
Post by colirv »
IIRC on mine it appears automatically on the bottom right of the screen. Are you sure it's not there?!
Colin
BMW R1250RS
https://www.namrider.com
Scarecrow
Re: Dashboard
Post by Scarecrow »
is it there all the time or just when your actually navigating/
electro_handyman
Been liked: 32 times
Re: Dashboard
Post by electro_handyman »
There is option to show many different 'icons' in the lower right corner. Default view is for the direction(N,S,E,W).
If you touch the white(or black depending on day or night) box it will give you a selection list of other options that you choose from.(you can only select one at a time).
There are many options to pick from, some are only available while navigating a route, others can be available all the time.
colirv
Has liked: 53 times
Re: Dashboard
Post by colirv »
Scarecrow wrote: Tue Jun 29, 2021 9:48 am is it there all the time or just when your actually navigating/
It's on the map page, which only shows a destination when you're navigating, IYSWIM.
Colin
BMW R1250RS
simoncrewe
Has liked: 46 times
Been liked: 37 times
Re: Dashboard
Post by simoncrewe »
Scarecrow wrote: Tue Jun 29, 2021 9:19 am I'm pretty sure on my 590 I had the option of arrival time (destination)
Any help please
As others have said you can only select it whilst navigating a route.
Scarecrow
Re: Dashboard
Post by Scarecrow »
Thanks Guys
