Motorcycle 2016 Africa Twin
emerrryjones
Post by emerrryjones »
Product comparison - shark navigator lift-away upright vacuum vs. Bissell cleanview with onepass 9595
Having a vacuum cleaner in the house is essential for most families in modern times. However, when there are numerous products from various manufacturers introduced to the market at different prices, customers may have a headache choosing an appropriate machine for their homes and require Shark navigator lift-away reviews for those. In this post, we will bring a detailed comparison between a cheap-price model from Bissell: Bissell Cleanview With Onepass 9595 and a series of popular vacuums from Shark: Shark Navigator Lift-Away Upright Vacuum.
DESIGN
Both are upright vacuum cleaners with a 25-feet power cord. A Shark navigator lift away upright vacuum is about 1.15m high while Bissell 9595 is about 80cm. However, the Bissell model can automatically adjust its height while this feature is absent on the Shark machine. This makes the former a little more convenient than its competitor.
Bissell 9595 weighs 6.8kg while a Shark lift away upright vacuum is about half a kilo lighter. The brush width of the Bissell is near 35cm while the number for Shark models is about 25cm. However, Shark navigators come with a larger canister of about 4.4l while the dustbin capacity of Bissell 9595 is only half of that.
One more thing that is present only on the Bissell is the protected bumper. This part is located in front of the vacuuming head, preventing it from breaking when accidentally hitting other furniture.
FEATURES & PERFORMANCE
The filtration systems of Shark navigator lift away upright machines and Bissell 9595 are similar, including a HEPA filter and several other ones that are washable. However, Shark models are equipped with the Anti-Allergen Complete Seal technology that helps obtain 99.9% of dust and debris while Bissell 9595 doesn’t have. Instead, Bissell 9595 comes with a turbo brush that allows users to clean pet hair and perform a deep cleaning on carpets more effectively. Moreover, model 9595 can vacuum dirt from the edges of the vacuum head. This feature is called dual edge cleaning, which can help reduce the amount of time cleaning because of the wide range of vacuuming.
Compared to Bissell 9595, Shark navigator lift away upright vacuum have several features that make users more convenient. The first thing is the swivel steering, which allows householders to move the nozzle to clean every corner around their standing position without turning the device around. The second function is the brush roll control with a control tab located on the handle. Users can adjust this tab to shut off the dusting brush when cleaning hardwood floors or maneuvering from bare floors to carpets.
Overall, both Shark navigator lift away vacuums and Bissell 9595 are good at floor cleaning, they can also perform well on carpets and are effective in collecting pet hair. However, with the Never Lose Suction technology, Shark navigators can maintain the vacuuming consistency better and make the floors a little cleaner than Bissell 9595.
About customer service, Shark provides a 5-year warranty for these models while Bissell 9595 is guaranteed up to 2 years.
CONCLUSION
In general, Shark navigator lift-away is considered better because of the consistent performance and other useful features, but Bissell Cleanview 9595 is also a great choice for those who don’t want to spend more than $100 for a vacuum.
