660 LM not announcing turns
Has liked: 110 times
Been liked: 254 times
Re: 660 LM not announcing turns
Excellent! Pain in the butt but that seems like a relatively easy fix.
Yodac
Has liked: 4 times
Post by Yodac »
Yes, I hope the info is helpful to others on the site.
Yodac
Has liked: 432 times
Been liked: 956 times
Well done for finding the answer - but I don't understand why it was announcing turns before your stop, if it was the English Language Files that were at fault. That doesn't make sense.
Unless it was the stopping the device and restarting it that cured the problem. My 660 used to do odd things after it had been navigating for a while. For example, the screen redrawing would start to get slow, then it wouldn't bother and I'd end up with a motorcycle icon and a track but no map drawn undernath it. Doing a restart always fixed it - which was possible to achieve on the move. The explanation that I gave to myself was that it had a 'memory leak', where memory is used by different functions but is not properly released when it the function finished - so the amount of available memory slowly went down. I don't know if that was what was actually happening.
It doesn't matter - you fixed it, and that is all that matters !
