Zumo 396 Mapping Software
VA3TWT
Has liked: 25 times
Post by VA3TWT »
My Zumo 550 is getting long in the tooth and I am considering replacing it with a Zumo 396 LMT-S. I detest Basecamp with a passion (steep learning curve for this old fella) and I am wondering , can I still use Mapsource with the new unit?
I'm guessing I will miss out on a lot of features of Basecamp, but until I learn that software, I would really like to keep using Mapsource.
Thanks for any and all advice;
Gord
Zumo 595LM
2010 GL1800 Goldwing
Re: Zumo 396 Mapping Software
Yes, all new devices can be used with MapSource provided you switch them from mtp to mass storage mode
Fitz
Been liked: 3 times
Ireland
Post by Fitz »
I've recently made the same journey from 550 to 396LMTS and so far I'm delighted with it.
Like you, I hated Basecamp and before buying the 396 had been designing routes in Google Maps, converting with GPS Visualizer which created files that Basecamp could open as a Track, convert to a Route and load to the 550. Phew! But...
But... since spending a bit of time learning about Basecamp using the excellent guides from New England Riders and Garmin Guru (see the "learning & using Basecamp" thread in the Basecamp for PC section of this forum), I'm a changed man. Well worth giving it a go.
VA3TWT wrote: Thu Aug 02, 2018 12:34 pm My Zumo 550 is getting long in the tooth and I am considering replacing it with a Zumo 396 LMT-S. I detest Basecamp with a passion (steep learning curve for this old fella) and I am wondering , can I still use Mapsource with the new unit?
Gord
VA3TWT
Has liked: 25 times
Post by VA3TWT »
Thanks Fitz! I will have a look at that thread. Maybe I will get it through my thick skull yet. Are you liking the 396LMTS?
Gord
Zumo 595LM
Sleuth
Has liked: 14 times
Been liked: 16 times
Belgium
Post by Sleuth »
Hi,
If you can use MapSource, then the switch to BaseCamp is not that huge. It does take a change from a file point of view to a database point of view. It is worth struggling, and fighting with it.
I have had to switch, and enjoyed a love hate relationship with BaseCamp. That was until I understood how things worked. The old Zumoforums helped out, and a large number of the old crew have signed up here. So if you have questions, ask. I am sure there is someone who can help.
Stupid questions rarely not exist, stupid answers exist frequently. A question means you do not understand soemthing.
Best regards
Sleuth
Maps: Europe NTU 2024.10
Been liked: 266 times
I too struggled with Basecamp but with the help of you tube videos I have started to figure it out!
Its well worth learning to use it
But as [mention]Fitz[/mention] says have a look at this thread
viewtopic.php?f=16&t=12
Yeah, I'm in the "struggled with BC" camp too but the newenglandriders tutorial is what made it make sense to me. The file system is a little goofy & takes some getting used to but it makes sense, sort of.
VA3TWT
Has liked: 25 times
Post by VA3TWT »
I have printed the newenglandriders tutorial and will have a read. Thanks for all the tips and encouragement.
Gord
Zumo 595LM
Breezly
Has liked: 22 times
Been liked: 33 times
Post by Breezly »
I would suggest that you don't just "have a read" of the tutorial. Set aside a couple of hours and start from the beginning of the tutorial with Basecamp open and follow the tutorial step by step doing them on your computer & GPS. The tutorial was developed from classes we've taught and it's meant to be a step by step guide - not as a reference material.
VA3TWT
Has liked: 25 times
Post by VA3TWT »
Thanks Breezly,will do.
Zumo 595LM
