"Calculating Route" does not work on my 665
93aspy
Post by 93aspy »
Hey guys and gals,
So when I download a new route from base camp and go to import the route in my 665, the "calculating route" window pops up but does not update. Not a show stopper because the route does finish and says it's complete, but I would sure like the calculating route window to work as it should.
Anyone have any ideas??? All comments appreciated.
Re: "Calculating Route" does not work on my 665
Its been a while since I used a 660, but I know that it is not compatible with Basecamp. Basecamp was updated considerably to cater for the newer devices with the trip planner App - some years ago now. Maybe Basecamp is sending it routing points that it doesn't know what to do with. ?
Mapsource is still available and is recommended for the 660/665. Try a simple route with that, see if it solves the problem.
Its also possible that it is calculating a rapid route back to where you are now. With the 66x devices, never have your end point anywhere near your start point, and try not to design a route that crosses or meets itself.
