Avoiding buying sat nav and charging the zumo xt
TripleThreat719
Has liked: 5 times
Been liked: 31 times
Re: Avoiding buying sat nav and charging the zumo xt
Post by TripleThreat719 »
HarveyM wrote: Mon Sep 13, 2021 12:34 pm
TripleThreat719 wrote: Tue Sep 07, 2021 10:11 pm Yes... The Zumo XT will provide you with greater coverage than cellular service because it is receiving its signal via satellite, rather than cell phone towers. It even does a remarkable job in fairly dense tree coverage.
Your cell phone also uses satellite networks for it's GPS rather than cell coverage. The only difference is what jfheath mentioned above.
Yes - but the satellite signal reception on my Zumo XT is considerably stronger than my iPhone...
