Current Basecamp is 4.7.4 (PC) https://www.garmin.com/en-GB/software/basecamp/
Current Express is 7.8.1.0
Current software for Z590 is 3.30
Current WIndows is 10 - but if you managed to keep Win7 going without accidentally installing 10, that is a neat trick.
new PC
- Has liked: 427 times
- Been liked: 934 times
Re: new PC
Re: new PC
I installed the latest version of GA, downloaded maps. Still have the same issue, I cant see my subscription maps without the GPS plugged into the PC. I did get to a screen to "unlock" my maps but there is no way to unlock it.
Re: new PC
You haven't yet answered my questions which may help us help you:
Are the maps ones that came originally on your device or did you add them later? If so how and what maps were they? The instructions you posted above refers to handhelds.
If they came with the device from new they won't appear in purchased maps.
Re: new PC
there are a subscription set, they were locked. Had to call Garmin to unlock, they fought it too.
thanks
thanks
Re: new PC
Ah ok, I understand now and why Garmin would have had to resolve this. It's why complete information needs to be given when seeking help as had that been known at the start our help could have been correctly targeted.
