Hello folks,
Can anyone advise why, when I export a route file (Basecamp generated gpx file) from the Micro SD card to the internal memory of my XT, the route sometimes becomes corrupt, with random straight lines across certain parts of the route.
I've tried to attach a pdf to show what I mean.
Many thanks in advance.
Bfn.
dommy99
Import from Micro SD Card
Re: Import from Micro SD Card
Oooops, sorry, should have checked that before attaching, try this one !!
- Garmin.pdf
- (1.26 MiB) Downloaded 413 times
Hello sussamb,
The maps are both he same, I played with various settings / avoidances etc. etc. just to check that those in Basecamp are the same as on the XT and they seem to be
Bfn.
dommy99
Bfn.
dommy99
That is odd and I can't see from the pic what could be causing it. Try going into settings on your Zumo and force a recalculation by switching from Fastest to Shortest route, assuming you have Fastest selected, if not switch to Fastest from Shortest. Does that remove the straight lines?
Hello sussamb,
I switched from fastest time to shortest distance on the XT, and the straight lines disappeared, but of course other parts of my "carefully planned" route (lol) also changed ! Mmmmm.
I will experiment further !!
Thanks for your help.
Bfn.
dommy99
Bfn.
dommy99
