Good morning, problem with the track
- Been liked: 1 time
How do you increase the thickness / width of the track? Thanks for your help
- Has liked: 361 times
- Been liked: 769 times
Re: Good morning, problem with the track
Hi
Welcome again.
If you have not enabled Garmin Explore on your XT - then using the XT in Landscape Mode
Track -> Track Icon, top left , Choose track, Spanner (top left), Track width.
Let me know if this method doesn't work.
If it doesn't work - do you use explore.garmin.com ???
Welcome again.
Hello and thanks.
As you say in manual mode the method does not work.
I normally use Garmin Express
Hello
Hello
thank you very much for your time and your availability, but I'm not a good programmer and I didn't understand what and how to do. So forget it, I've already messed up my XT. Thanks again. Hello .
You can always reset your XT to how it was when you bought it.
Settings -> Device -> Reset
Impostaz -> Dispositivo -> Reimposta
