Garmin Express Version 7.10.0.0 Now Availalbe
- Has liked: 29 times
- Been liked: 39 times
Re: Garmin Express Version 7.10.0.0 Now Availalbe
Changelog now posted:
Garmin Express v7.10.0 is available for Mac. If you would like to update to the latest version, please visit the “About Garmin Express” page from the Garmin Express Menu and select “Check for Updates to Express.” This version includes the following changes:
Fixed an issue with the Hub continuing to show an update is available after it’s been completed.
Fixed a number of links within Help with the new URL’s.
Other minor bug fixes and improvements.
I can't remember when the last time was Garmin Express worked on my mac. I installed. reinstalled, uninstalled and re-reinstalled multiple times. The trick is now to do it through wifi. I can't understand why a brand that makes such expensive hardware, fails on multiple fronts. Garmin Express, Basecamp, and the XT cradle saga. Incredible.
I have had no issues, once I realized how the darn thing works (not like windows) so all my updates are done here on the Mac.
However, if you have an older version of windows (say windows 7), you can get a piece of software called VMWare and you can run a windows program under it. I use it to let me use the real old but workable Microsoft Streets and Trips.
