Tourtech Locking Garmin Zumo XT Mount
simoncrewe
Has liked: 47 times
Been liked: 38 times
Re: Tourtech Locking Garmin Zumo XT Mount
Post by simoncrewe »
I think you may well be correct for that reason! Sorry for any confusion.
axamax
Has liked: 7 times
Been liked: 10 times
Post by axamax »
Scarecrow wrote: Fri Feb 19, 2021 1:30 pm
Axamax
Could the unit be used inverted e.g. with the lock positioned at bottom left rather the top right of the mount
Cheers
Del
iankim wrote: Fri Feb 19, 2021 6:54 pm I don't think it would work upside-down as the Zumo mount locks the release leaver on the Garmin Mount.
As Ian said you'd need the release lever at the bottom to do that. That would give you an upside down screen.
Scarecrow
Been liked: 27 times
Post by Scarecrow »
a
All fitted .
I was worrying needlessly there's plenty of room for the Key. I've fixed it above the clocks on my existing Kawasaki GPS mount rather than a ram mount.
Still a pity Garmin didn't include some sort of secondary security loop .
simoncrewe
Has liked: 47 times
Scarecrow wrote: Sat Mar 20, 2021 4:49 am a
All fitted .
Before I got my TT mount I just put a self adhesive cable tie mount on the rear of the case & attached a tether.
https://uk.rs-online.com/web/p/cable-ti ... lsrc=aw.ds
